98 Dodge Ram 1500 (5.2) clutch issue
Old 02-26-2024, 10:09 AM
jakefarmer's Avatar
jakefarmer
jakefarmer is offline
When you compress the slave, you are forcing fluid back up the line, so, level in reservoir rises. When you push in on the pedal, you are pushing fluid that is already in the master cylinder piston down to the slave, so, reservoir level won't change much, if at all. That's normal.
ahhh okay, I did not know that. Thank you. I just assumed it would at least move a little
Quick Reply: 98 Dodge Ram 1500 (5.2) clutch issue
