97 dodge ram 1500 5.9L overheating, no codes??
Old Mar 17, 2024 | 11:27 PM
97R-15's Avatar
97R-15
Default 97 dodge ram 1500 5.9L overheating, no codes??
Did gaskets from the heads up, also replaced broken ect sensor and connector, and ect sender. Also replaced thermostat with a 195° motorad.
no codes, runs great, but consistently heats up with no signs of slowing even up to 230° or so.
heat gets warm with temp and gets warmer with acceleration.
no leaks. . .
​Can anyone help???
Old Mar 18, 2024 | 12:49 AM
AtomicDog's Avatar
AtomicDog
Sounds like you may still have an air pocket in the cooling system to cause it to overheat so quickly or you have a defective thermostat (not uncommon these days, even new). If you have a laser temperature gun (something like this - https://www.harborfreight.com/201-in...rms-64847.html), you can point it at the thermostat housing, radiator hoses and the temperature sensor on the intake to see what the coolant temperature is actually running.
Old Mar 18, 2024 | 12:51 AM
97R-15's Avatar
97R-15
Okay thanks, I'll jack it up in the front tomorrow and try to purge the system of air. And I'll grab a Lazer temp gun from work. Lyk what happens.
