Motor Replacement
Old Mar 27, 2024 | 08:26 PM
MtnTow's Avatar
MtnTow
Never pulled an engine before?
-take lots and lots of pictures of wire routes, hosing etc. Then take more.
​​​​​​-make.sure you have plenty of cribbing to support things like tranny, exhaust.
-have plenty of string and bungies to hold things out of the way.
-comes out easiest with hood off, rad out and some say undivorced but i always do.
-watch your rear wiring harness & crank sensor wires when putting engine back in.
-locktight on flexplate bolts even if LIT says no.
-keep bolts seperated by top/bottom in buckets or something. Labels if need be.
hmmm..... probably a few others im not thinking of. Dont let the fan take out your rad. Lol
Old Mar 28, 2024 | 02:28 PM
BrendonM's Avatar
BrendonM
Originally Posted by AtomicDog
Depends on how much you plan to spend and how bad the rod knock is. You might get lucky and just need to replace the rod bearings on the offending knocking rod if the crank isn't beat up real bad, if you wanted to repair the motor cheaply..
Personally, I'd opt to go with a 5.9 to give yourself more torque and power. It bolts into the same place as the 5.2 engine and uses the same 46RE transmission.
Hearing ya loud and clear! Definitely taking my time. Also a new 5.9 isn’t in budget as of rn. All I have is the 5.2 wit rod knock km taking out. I planned on just doing a mild “street” build of sorts. Like fix the rod knock and than cam it with an intake and some other **** maybe not sure yet.
Old Mar 28, 2024 | 03:56 PM
AtomicDog's Avatar
AtomicDog
Completely understand. Sorry you didn't mention that you needed a motor before you picked up the used 5.2. The 5.9 should run about the same price used and all you need is the 5.9 flexplate (with weights on it) for the conversion. Of course, you may need to re-use your existing intake and exhaust manifolds from the old motor, but those 5.2 and 5.9 parts interchange.
Old Mar 29, 2024 | 09:17 AM
BrendonM's Avatar
BrendonM
I thought you had to do something with the PCM for it to acknowledge the extra displacement wit the 5.9
cause if that’s true, I’ll just get a used 5.9 and build it
i just don’t wanna spend more then I need to
Old Mar 29, 2024 | 10:36 AM
AtomicDog's Avatar
AtomicDog
Lightbulb
It should run with the original PCM, but might not be perfect. You can certainly have the existing PCM updated/flashed with a new tune to better handle the 5.9 engine.
Old Apr 1, 2024 | 03:26 PM
BrendonM's Avatar
BrendonM
hey what about a hemi swap?
Old Apr 1, 2024 | 03:48 PM
LOTS of work, and the stock PCM won't have a clue about it. You would need to do some serious adaptation get a hemi to work. One member that tried this, installed the third gen dash into his truck. But, after working at it for a couple years, he finally gave up, and sold it.
Old Apr 2, 2024 | 06:55 AM
Moparite's Avatar
Moparite
Can be done, use the motor, trans, harness and the pcm. You can get a wiring harness to do the swap but they run around a grand(the last i checked).
Old Apr 2, 2024 | 09:19 AM
AtomicDog's Avatar
AtomicDog
Question
Do you happen to know if that harness will make the stock 2nd gen gauges work with the Hemi motor and transmission swap? Lastly, do you have a link to who makes that harness?
