Leaking from vacuum pump/power steering assembly (again)
Old Apr 2, 2024 | 03:19 PM
That_red_dodge's Avatar
That_red_dodge
Unhappy Leaking from vacuum pump/power steering assembly (again)
Hello! My truck started leaking engine oil from the vacuum pump a while ago so I ordered a rebuild kit and rebuilt it. Now it’s leaking power steering fluid from the same place (see picture) Do I need to buy a new power steering pump or did I not reassemble the vacuum pump correctly with the o-rings? What should I do?!
Old Apr 2, 2024 | 03:49 PM
Maybe just a bad seal somewhere...
Old Apr 2, 2024 | 03:52 PM
That_red_dodge
Yes for sure, but I'm just confused of what seal and if its the vacuum or the power steering pump... I find it a bit odd that its leaking from there, usually its engine oil that leaks there...
Old Apr 2, 2024 | 04:04 PM
HeikIlm's Avatar
HeikIlm
If that is PS-fluid, there really is not many places it to leak, and it's the pump shaft seal. I replaced pump to my truck for that very reason.
Old Apr 2, 2024 | 04:15 PM
That_red_dodge
Is the pump shaft seal the big one you change when rebuilding the vacuum pump? Or is it directly on the powersteering pump? Because I remember when rebuilding mine there was a very small groove on the powersteering shaft, I passed a scotch brite to help it a little could that be the problem? And if it's the problem I trought it would leak engine oil and not power steering fluid... I'm so confused
Old Apr 2, 2024 | 04:19 PM
AtomicDog's Avatar
AtomicDog
Is this a diesel or gas powered truck?
Old Apr 2, 2024 | 04:20 PM
HeikIlm's Avatar
HeikIlm
I can't recall. It's way over a decade when I rebuilt my vacuum pump, and less tha a decade when the power steering pump was replaced.
That_red_dodge
It's a 2500 2000 Diesel
Old Apr 2, 2024 | 04:21 PM
HeikIlm's Avatar
HeikIlm
Diesel.
Old Apr 2, 2024 | 04:24 PM
That_red_dodge
No worries, i'm thinking of buying a new powersteering pump then, since they are not the most expensive part and since the shaft on mine is already grooved. Is there a popular, good workig replacement that you know of?
