transfer case question
Old Jan 8, 2006 | 10:50 PM
motodog1's Avatar
motodog1
Default transfer case question
anyone know the differance between the 231d and the 231dhd transfer case and are they interchangable?
Old Jan 8, 2006 | 11:07 PM
shott8283's Avatar
shott8283
Default RE: transfer case question
well not knowing anything about trannys or t cases.. assuming the HD means heavyduty.. and the numbers seem to match up... so assuming under the assumptions that i have made... yea why not... but you know when you assume it makes an *** out of U and ME... judt kidding...but thats my best estimated geuss... wait for more responses
Tani1500's Avatar
Tani1500
i dont know if the 231 is but i know you can swap in a NP241 or NP241HD i dont think you want to go lighter on the t case anyway.
Old Jan 8, 2006 | 11:59 PM
The Burning Rom's Avatar
The Burning Rom
I don't believe they made a 231d model. The "D" designation is for Diesel...and was only used on V10/Diesel models that DIDN'T have the HD upgrade.
As far as all the tranfers cases...here's the model differences
The NV231 transfer case is used behind many V6 and V8 engines in pickups and sport utility vehicles.
The NV231HD, used in the 1994+ Ram with V6 and V8 engines, features larger bearings and a wider chain than the NV231. All versions of the 231 cases use three gears in the planetary reduction set.
The NV241 is essentially a NV231HD with six gears in the planetary set.
The NV241D is a heavier duty Dodge version of the 241, with a larger input shaft and larger bearings to withstand the torque of the V10 and diesel engines.
The NV241HD, an option on Ram 2500's and standard on Ram 3500's built after 1998, has a stronger case and wider drive chain to better withstand the shock of snow plow service, a PTO cover and drive gear, and an extra bearing to support the thrust to the main shaft created by a PTO adapter.
Old Sep 24, 2007 | 02:52 PM
lrrman's Avatar
lrrman
Just crawled under my dakota and the tag says 231D HD. Build date is 2/98 even though the truck is a 99?
Old Oct 27, 2011 | 09:07 AM
BigBlue83's Avatar
BigBlue83
Default 231D transfer case
i heard that a 231D transfer case was for diesel engines however i have one on my 98 ram sport v8 magnum. (i just got the truck two months ago) i would like a new transfer case to help resolve some issues. what can i use for a transfer case? i cant seem to find a 321D.
Old Oct 27, 2011 | 09:12 AM
The "D" designation is for Dodge. "J" is Jeep, etc.
231 DHD has a wider chain, etc. It is indeed the "heavy duty" version.
