2001 dodge ram 1500 4x4 46re problems
Old Apr 12, 2024 | 04:46 PM
What were the codes??
have a look at the 8 pin connector at the trans, they like to pull, and expose copper, and short out.
Old Apr 14, 2024 | 04:09 PM
2001ramsam's Avatar
2001ramsam
p1762 is the only code I’m getting , this is the code my Bluedriver obd2 scanner is giving me
Old Apr 14, 2024 | 04:14 PM
Thats a governor pressure sensor volts high. Check your wiring. If that's ok, bad sensor.
Old Apr 14, 2024 | 04:16 PM
2001ramsam's Avatar
2001ramsam
Thanks again for the fast reply! Any suggestions or where to find a wiring diagram to help a fella out in the process ?
Old Apr 14, 2024 | 04:39 PM
Download the service manual for your truck from here. Wiring diagrams are in section 8W.
Old Apr 14, 2024 | 04:40 PM
2001ramsam's Avatar
2001ramsam
Your the man, thanks for all your help! I’ll post how it goes
Old Apr 14, 2024 | 04:45 PM
Yep, keep us updated.
Old Apr 14, 2024 | 07:02 PM
2001ramsam's Avatar
2001ramsam
Where is the 8 pin connector you speak of , I was looking at the clip with 3 wires going into it just above my pan on the drivers side. But can’t seem to find 8 pin connector, or is this the 8 pin on the inside?
Old Apr 14, 2024 | 07:05 PM
Drivers side, about halfway back, plugs straight down into the top of the valve body. If you truck is a 4x4, it's a right pain to get to.
Old Apr 15, 2024 | 09:38 PM
2001ramsam's Avatar
2001ramsam
Is there Anychance this could be a computer problem? Should I try disconnecting my battery and turning the key to the on position for 30 seconds? I heard this was the solve for a couple people with a 42re having similar problems with the same code
