47re no gears when warm
Old Apr 29, 2024 | 05:35 PM
DylanL05's Avatar
DylanL05
Default 47re no gears when warm
I have a 96 12 valve with a 47 RE will shift through all gears when first started up about five minutes and it loses all gears does not try to engage. I have been told torque converter I have one. I can put in it, but I want to see if anyone else has any ideas. The fluid is pink smells a little burnt, but isn’t terrible.
Old Apr 29, 2024 | 06:05 PM
AtomicDog's Avatar
AtomicDog
Is the transmission full of fluid as measured on the dipstick when warm?
Old Apr 29, 2024 | 06:28 PM
DylanL05's Avatar
DylanL05
yes it is at correct level checked in netrual
Old Apr 29, 2024 | 09:14 PM
DerTruck's Avatar
DerTruck
An easy test with the electronically controlled transmissions is to unplug the connector on the side of the transmission and see if 1,2,3 and reverse can be manually shifted. Overdrive and lock-up won't work obviously.
Old Apr 29, 2024 | 10:23 PM
DylanL05's Avatar
DylanL05
thank you I’ll try it! And if it does have the gears, what would I look into next?
Old Apr 29, 2024 | 10:42 PM
AtomicDog's Avatar
AtomicDog
Have you plugged in an OBD2 scanner? Getting any stored or pending codes related to the transmission before you unplug the electrical connector on the transmission?
Old Apr 30, 2024 | 09:08 AM
If the trans works with the electronics disabled, replace the electronics......
Old Apr 30, 2024 | 11:26 AM
DylanL05's Avatar
DylanL05
no codes at all.
Old Apr 30, 2024 | 01:36 PM
DylanL05's Avatar
DylanL05
Also forgot to mention was have bad tc lock up issue then installed a switch and when you’d engage it then disengage the switch the tc would not unlock and would stall the truck
Old Apr 30, 2024 | 02:30 PM
Its rebuild time.
