Jet power chips.
Old May 12, 2024 | 06:57 PM
Oldtrucksarebest's Avatar
Oldtrucksarebest
Default Jet power chips.
I have a 1998 ram 1500 with a 5.9l. Has anyone tries jet performance chips? Did they make any improvements? What stage did you use? Thanks
Old May 12, 2024 | 07:56 PM
Well, it installs between the PCM, and the black harness connector. It advertises "Up To" 25 hp... (stage 1) I don't have time to see what all is on that connector for the PCM, but, it would bear some investigation. For the money they want for it though, I would be more tempted to put the money toward a tune/tuner..... Likely get better results.
Old May 13, 2024 | 06:51 AM
Moparite's Avatar
Moparite
From what i have herd all it does is fool the pcm in thinking the temp is cooler than it actually is and the pcm give it more fuel.
