Hello y'all i got a 2002 dodge ram 2500 4x4 diesel it has a 6 speed transmission && the other day when it was running in neutral all of a sudden its started jumping out of no where ran out && pushed the clutch pedal in && it stopped but when i released the clutch pedal it did the same thing but the thing was it was in neutral still so a friend told me its in gear still so how do I take it out of gear or whats the problem?? I clutch burned up so i replaced it && its still doing the same thing any thoughts out there.
When i put it in 2nd it wont go at all. i have to keep the clutch pedal pressed so it wont go off even if its in neutral, but when its in neutral && i let the clutch go it starts to go forward when its in netural never has a problem with anything truck is stock.
