Hardlines on transmission crossmember
Old May 24, 2024 | 03:35 PM
Imamekanik89's Avatar
Imamekanik89
Default Hardlines on transmission crossmember
Hello all,
I have a 2001 ram 2500 with a NV5600. I just replaced the clutch on my truck and now going back together with it. During removal, my uncle who was helping me, removed 2 hardlines that mount to the front of the transmission crossmember/support. Are these vacuum lines? There is a red tipped and black tipped tube that connect to those hardlines but he doesn't remember which color connects to which tube. Does anyone have a schematic or picture of how they connect. Thanks in advance!
Old May 24, 2024 | 04:28 PM
HeikIlm's Avatar
HeikIlm
Yeah, they are vacuum lines for the front axle CAD. Check posts #4 and #5 on this thread: https://dodgeforum.com/forum/2nd-gen...-into-2wd.html
Old May 24, 2024 | 05:43 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Originally Posted by Imamekanik89
Hello all,
Those lines also tie into the transfer case. You should be able to find a schematic in the factory service manual. You can download the manual for your year truck via this link - https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old May 25, 2024 | 09:28 AM
Keith_L's Avatar
Keith_L
Definitely blow through them with compressed air (just the hardline part) and make sure output at the other end seems proportionate.
Tiny bits of gravel can get in there MUCH more easily than you think. I fixed no CAD engagement once by blowing them out. I thought one seemed restricted, but then convinced myself it was probably fine. At the last second I heard a "pop" and it blew out something. Flow was much improved and CAD engagement was restored.
By the same token, if the lines are crushed.....
Old May 25, 2024 | 10:41 AM
Yeah, mine accumulated some water, which then froze.... No 4wd..... Put in the garage with a heater for a while, blew 'em out with air, all good.
Old May 25, 2024 | 11:51 AM
Keith_L's Avatar
Keith_L
Also to the OP: at the risk of stating the obvious, vacuum is vacuum. If the hardline(s) are mangled beyond repair, you can run standard vac hose or whatever. Just anchor well and route carefully. The hardlines are cleaner and more elegant but that's it.
Old May 26, 2024 | 08:25 AM
Could even get a couple appropriate lengths of brake line, and bend them to suit.
Old May 27, 2024 | 08:20 AM
Moparite's Avatar
Moparite
That's what i did, One of my lines allowed water in and rusted up solid.
