Replacing coil springs
Old Jun 2, 2024 | 12:36 AM
KameronG11's Avatar
KameronG11
Default Replacing coil springs
I've got a 97 dodge ram 1500 4x4 that I plan on replacing the coil springs on. I've rebuilt the front end but still have a rough shake when hitting bumps. I'm wondering how hard it is and what the easiest way to to about it is. I was also gonna try to replace my control arms and I got the bolts closer to the rear off on the lower arms but the two front ones won't break loose at all
Old Jun 2, 2024 | 01:53 AM
AtomicDog's Avatar
AtomicDog
Those front coil springs are usually not an issue. Did you replace the front shocks with good quality shocks as part of the front end rebuild and properly tighten/torque the shock bolts? Also, the bushings in the control arms are something to check out as well.
Old Jun 2, 2024 | 02:01 AM
KameronG11's Avatar
KameronG11
yeah i replaced the shocks with rancho 5000s and tightened them like they're supposed to be. I don't really know what bad control arm bushings look like but I assume mine are probably bad, they're sorta flattened out
Old Jun 2, 2024 | 02:10 PM
KameronG11's Avatar
KameronG11
I figured atleast one coil spring was bad because when I hit a rough bump on the left side of the truck it feels almost like the wheel is coming off the ground but when I hit a bump on the right side it still shakes but doesn't shudder
Old Jun 2, 2024 | 03:39 PM
AtomicDog's Avatar
AtomicDog
I'd replace those control arm bushings first. Good shocks should tame the bounce from the front springs, but if you have bad control arm bushings, you could experience all kinds of wandering and knocks depending on road conditions.
Where, in general, are you and do you have any photos of the front springs and control arm bushings you can share here?
Old Jun 2, 2024 | 03:55 PM
KameronG11's Avatar
KameronG11
I don't have any but I'll post some pics on here when i get some
Old Jun 2, 2024 | 04:59 PM
AtomicDog's Avatar
AtomicDog
Where, in general, are you?
Old Jun 2, 2024 | 05:06 PM
KameronG11's Avatar
KameronG11
I'm in West TN
Old Jun 2, 2024 | 05:11 PM
AtomicDog's Avatar
AtomicDog
Thanks. I'm guessing that the roads there aren't the best maintained roads around?
Old Jun 2, 2024 | 05:35 PM
KameronG11's Avatar
KameronG11
[QUOTE=AtomicDog;3588522]Thanks. I'm guessing that the roads there aren't the best maintained roads around?
No they're definitely not, ive also never owned a 2nd gen so im not sure how they normally ride on rough roads
