Low idle, misfiring
Old Jun 17, 2024 | 11:46 PM
Alexdabest's Avatar
Alexdabest
Default Low idle, misfiring
01 5.9 magnum engine. Is idling low and running rough. It tries to stall (and does occasionally) when coming to a stop. Gets TERRIBLE gas mileage currently. And it misfires and ticks from the pasenger side of the engine bay while driving, but mostly only at cruising speeds and around 1k-1600 rpms.
keep in mind, the truck is very mildly cammed and has EQ heads, and many other aftermarket things.
I didn't have any issue until my pcm went haywire. I replaced it, but it didn't fix the issue fully. Since, I have replaced: injectors, plugs and wires, cap and rotor, ALL manifold and throttle body sensors, ignition coil, O2 sensors, ALL lifters, ran a fuel pressure test, compression test, vacuum test, and leakdown test and have zero negative results. Also had a mechanic hook it to a snap-on scanner. He told me it was something in cylinder 2 (no codes mind you), and I've recently redone everything on it.... brand spanking new injector, plug, wire, lifters, etc.
I'm at a loss.ive check vacuum, relays, the fuel pump, and more. I'm just at a loss. Is it possible that I just need a mild tune on it to fix this??? Any input would be greatly appreciated. Thanks!
Old Jun 18, 2024 | 07:53 AM
Has it been doing that since it was put together with the new parts?? IF the answer to that is "yes", then yeah, I am thinking a good tune would be the place to start.
Old Jun 18, 2024 | 08:02 AM
Alexdabest's Avatar
Alexdabest
Yes, it has. Ill throw my hp tuner on it and play around with it a bit later. Bye bye pcm warranty😂
