Rear axel rebuild
Old Jul 9, 2024 | 03:01 PM
Mneukirch86's Avatar
Mneukirch86
Default Rear axel rebuild
So I have a 2001 dodge ram 1500 four-wheel-drive Laramie with the 5.9 V8 and I need some advice on proper kit to get to replace my rear end bearings, etc. I don’t have a lot of info on the rear end, but I do have a photo of the glove box codes
I don’t know if there is any benefit to changing the ratio on the gears to get better economy or anything, but even just information on what I have to do to replace it as factory
Old Jul 9, 2024 | 03:46 PM
AtomicDog's Avatar
AtomicDog
It should be a 9-1/4 rear in that truck. You will need a bearing kit, which should include the carrier and pinion bearings, pinion seal and rear cover gasket. Here's an example - https://www.ebay.com/itm/201386091216
You will also need to determine if you have a limited slip unit in the rear or not. If so, it's likely that the clutches in it are shot and need to be replaced. You can also find the limited slip clutches via numerous outlets, if needed.
You can reference the rebuild procedure in the service manual. You can download the service manual for your year truck via this link - https://dodgeforum.com/forum/2nd-gen...e-manuals.html
If you've not done this job before, especially if you're changing gear ratios, rear end rebuilds are best left to folks that do this type of work regularly.
As for your existing gear ratio, you should be able to determine it by either the tag that is on one of the cover bolts or by the ratio that's typically stamped on the ring gear.
Old Jul 9, 2024 | 04:07 PM
3.55 gears, it's listed on the option sheet.
Also, 4x4, so, it isn't just one set of gears that would need to be changed. Front and rear ratios MUST match, else, things go BOOM!
Old Jul 9, 2024 | 04:19 PM
Mneukirch86
thanks I’ll take a look at the axle when I get to my truck later. In the meantime, I did a vin decode search and came up with the build sheet. This is a screenshot of the section that explains the axles if it’s helpful.
Old Jul 9, 2024 | 05:50 PM
Moparite's Avatar
Moparite
If it had a limited slip you would see a DSA code under the DRB.
Old Jul 10, 2024 | 12:36 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
An example for the Anti-spin Differential.
DGB All 4-Speed Automatic Transmissions
DGTS 4-Spd. Automatic 46RE Transmission
DHAP Lock-Up Torque Converter
DHKS Shift-on-the-Fly,231HD Transfer Case
DJCS 195MM Front Axle
DMDP 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
EAGC All Gas Engine
EML 5.9L V8 MPI Engine
Old Jul 10, 2024 | 06:22 PM
Moparite's Avatar
Moparite
Where are you getting 4 letter codes?
DGT 46RE
DHA Lock-Up Torque Converter
DHK Shift-On-The-Fly,231Hd Transfer Case
DJC Dana M44/216Mm Front Axle
DMD 3.55 Axle Ratio
DRB Corporate 9.25 Ld Rear Axle
EAA All Engines
EAG All Gas Engine
Here is a pic of the body tag found on the front right side of the radiator support. Pic is from another user here.
Old Jul 11, 2024 | 08:44 AM
Moonpie's Avatar
Moonpie
For me, when I emailed Dodge Customer Care two years ago, the build sheet info they emailed me for my 2001 had both three- and four-letter codes:
Old Jul 11, 2024 | 06:33 PM
Moparite's Avatar
Moparite
I have a list of a ton of sales codes and all are 3 letter or letter and #. I was able to figure out what they are by leaving off the last letter. Don't know what the fourth letter is.
Old Jul 12, 2024 | 05:45 PM
Mneukirch86
