Reverse lights
Old Jul 13, 2024 | 02:39 PM
knightmoves's Avatar
knightmoves
Default Reverse lights
I have a 1998 ram 1500 5.2 with a 5 speed manual transmission. I’m working on the reverse lights and they only come on if I hold the shifter in place. If I simply shift it into reverse and turn the shifter loose the lights go out. I have to hold the shifter to the right to get the lights to stay on. I’ve replaced the switch twice and I get the same results. Is the shifter bad?
Old Jul 13, 2024 | 02:40 PM
Is the switch adjustable????
Old Jul 13, 2024 | 02:42 PM
knightmoves
no it just screws into the trans case.
Maybe something worn on the shifter, that is supposed to push the switch then.
