1997 Doge Ram 1500 4+4 5.9 litre shift lever adjustment
Old Jul 16, 2024 | 11:20 AM
Richrichy's Avatar
Richrichy
Default 1997 Doge Ram 1500 4+4 5.9 litre shift lever adjustment
So my shift lever for the automatic transmission needs adjustment It goes into Park , Reverse and Neutral and Drive but that’s as far as it gets it will not go and further down to lower gears. It feels loose on the steering column. I backed up on a
hill and it would not go into drive. So I’m researching how to adjust it cuz I don’t want to get stuck somewhere out in the bush here in Canada.. thanks
Old Jul 16, 2024 | 12:12 PM
Start with an inspection, sounds like you have some worn bushings in there.
Old Jul 16, 2024 | 12:39 PM
Richrichy's Avatar
Richrichy
Well tyvm but where? Hopefully not in the transmission itself but I don’t see any bushings in the linkage
Old Jul 16, 2024 | 12:56 PM
Basically where ever two moving parts come together. Or do you have a cable from the column to the trans???
Old Jul 16, 2024 | 08:34 PM
Richrichy's Avatar
Richrichy
Ok I’ll recheck the linkage it’s all steel Tks for the information
