Sensors & P1762 DTC
Old Jul 29, 2024 | 07:49 PM
Chiefs23's Avatar
Chiefs23
Default Sensors & P1762 DTC
I've read and seen on here how the upstream o2 sensor shares the same reference voltage as the governor pressure solenoid which can cause the P1762 DTC to appear. I found some frayed wires on my upstream o2 sensor harness and fixed and replaced them and the code went away for a few weeks. Well, now the code is back so my questions are; does the downstream o2 sensor share the same reference voltage as the governor pressure solenoid? Are there any other sensors that share the same reference voltage as the governor pressure sensor that could cause this P1762 DTC? When I started the truck it was in first gear every time and wasn't in "limp mode." Also it was going through all the gears so I'm curious as to why this code is back. Thanks!!
Old Jul 29, 2024 | 08:50 PM
You may actually have an issue with the solenoid..... How many miles on the trans?? Last time it was serviced??
Old Jul 29, 2024 | 09:05 PM
Chiefs23's Avatar
Chiefs23
Less the 2k. The transmission (Viper Series 2 46re) was purchased from PATC on May 1. It came with a one year unlimited miles warranty. I was told that if I dropped the pan within the year, the warranty is voided.
Old Jul 30, 2024 | 06:36 AM
Moparite's Avatar
Moparite
I would contact them and see what they say. Wonder what happens if the sensor is bad, Do you have to send the trans back for them to change it? Unless they have local trans shops that they work with.
P1762 Governor Pressure Sensor Offset Volts Too Low Or High
The sensor sends back voltage to the pcm to tell it what the output speed is. If you check your governor pressure with a gauge it will be about a 1 psi per mile per hour.
Old Jul 30, 2024 | 07:55 AM
Chiefs23's Avatar
Chiefs23
Heres the interesting part. I was getting the same p1762 code with the previous transmission and pcm before I bought and installed the new transmission and pcm. That’s why I’m confused. How could this be if the transmission and pcm are both new.
Old Jul 30, 2024 | 07:57 AM
Wiring issue.
