Need a new antenna, help!
Old Aug 11, 2024 | 09:55 PM
4stgs's Avatar
4stgs
Default Need a new antenna, help!
So, I’ve tried 2 different Amazon short antennas to replace my ailing 99 Ram factory unit, and I’m about to give up. Both stated they would work on a second gen. Nope. Are there any aftermarket short units that are a direct fit? I’ll probably head to LKQ and pick up a factory unit this week, I’m not sure why these manufacturers can’t get it right.
Old Aug 12, 2024 | 06:16 AM
Moparite's Avatar
Moparite
Are you replacing the whip or the whole antenna? Might want to look up some of the old threads on this.
Old Aug 12, 2024 | 11:33 AM
dodgetruck2's Avatar
dodgetruck2
I have ran into two different styles, there the black antenna with the plastic sleeve that covers the base, and the bare aluminum style with the coil wrapped around it. If I recall they each had a different thread design
Old Aug 12, 2024 | 02:13 PM
4stgs's Avatar
4stgs
Im just replacing the whip. None of the aftermarket have the same thread / stud as the factory. I’ve read that the stud in the base of the factory antenna should just unscrew so I can put one of the supplied ones from the antennas I’ve bought can be used. It’s really stuck, I’m going to try to remove today with PB and muscle.
Old Aug 13, 2024 | 06:02 PM
4stgs's Avatar
4stgs
Well, I snapped the stud off… I guess it was a little too corroded / tight / bent, who knows. Getting a junkyard replacement tomorrow.
Old Aug 14, 2024 | 09:04 AM
dodgetruck2
might have the same result with a junkyard unit, wouldn't hurt to check out a new one
