2000 dodge ram 2500 v 10 4x2
Old Aug 20, 2024 | 09:53 AM
Alfredo Rodriguez's Avatar
Alfredo Rodriguez
Default 2000 dodge ram 2500 v 10 4x2
Good morning to everyone I have 2000 dodge ram 2500 + v 10+4x2
Last week I did a transmission tune up and replaced two sensors they are together in the same in the same bracket, I noticed I have some parts in the oil panel and they are front the bands I put it back the front band and adjusted I replaced the spring for the 3 & 4 gear, and closed oil pump back putting fluid go for a test drive and transmission it works in only one gear, I think is in 3 gear because is a long gear, any help thanks you guys
Old Aug 20, 2024 | 03:47 PM
Those are the TCC and O/D solenoids....
Did the band strut fall out? How did you adjust it??
Old Aug 20, 2024 | 04:10 PM
Alfredo Rodriguez
Yes they are tcc and o/ d , The strut falls out and I put the valve body down because I couldn't get to the band and adjusted, I don't think the I adjusted correctly that what I did , and driving and is stuck in on gear it won't change up or even reduce gear
Old Aug 21, 2024 | 08:42 AM
May have missed a trick when you did the valve body... As I recall, there are a selection of little ***** in there, that operate as check valves, and they are NOT all the same size... and if the band is adjusted too tight.... yeah, that's gonna be a problem.
Think you are going to have to go back in there.... You can get the service manual for your truck from here, and go thru the valve body R&R procedure, see if anything changes...
Old Aug 21, 2024 | 10:47 AM
Alfredo Rodriguez
Thanks for all the help yes I will check, and I I appreciate it you send me the manual for my truck I will look at it into it
