Tire size help 315/70 17
Old Oct 5, 2009 | 09:07 PM
crazyval's Avatar
crazyval
Default Tire size help 315/70 17
I have a 2001 dodge ram 1500 4x4 sport + offroad pacage, can i fit a 315/70/17 bfg tire on without rubbing on anything? If not then what kind of lift do i need? Body or suspention lift? Thanks for the help
Old Oct 5, 2009 | 09:13 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Thats a little bigger than a 35" tire. You might be able to fit it. It will be TIGHT!!! Try a 305?
Old Oct 5, 2009 | 09:24 PM
crazyval's Avatar
crazyval
Already got them just want to see if they fit before i go throught the headache of putting them on
Old Oct 5, 2009 | 09:25 PM
Twisted Metal's Avatar
Twisted Metal
with either a body or suspension lift they will fit. Turning on the other hand.... Well, that is another matter.
Old Oct 5, 2009 | 09:27 PM
dodge15004x45.9
Might want to look at a leveling kit.
Augiedoggy's Avatar
Augiedoggy
I have 5 inches of lift and 35's barely clear when turning
Old Oct 5, 2009 | 09:32 PM
crazyval's Avatar
crazyval
So no way i can fit 315/70/17 without any kind of a lift?
Old Oct 5, 2009 | 10:05 PM
zje400ex's Avatar
zje400ex
I would doubt they will fit. An off-road ram is about 1.5-2" higher than a stock 4x4 ram. I've seen people fit 33's on an off-road but not 35's. A leveling kit would help but you will probably still rub when turning.
I'd look into a 5" lift kit with new control arms because you can't really go bigger than a 2" coil spacer since you have off-road coils. This would put about 3.5-4" of lift on your stock control arms and front suspension. Anything more than that should probably require new control arms and pitman arm. A 5" lift would be the way to go and plus it'd look sweet with those 315 70 17's. If money is an issue maybe a leveling kit would be just enough to clear them with some minor rubbing
Old Oct 5, 2009 | 11:39 PM
dodge15004x45.9
5" of lift needs new shocks all the way around new coils or spacers in the front. add a leaf or MASSIVE block in the rear. Look at an index ring for your t case. (If you off road and flex out the front drive shaft might/will bind.) New lower and upper control arms. New drop pitman arm. This is a good lift to check out. http://www.extremesuspensions.com/st...cat=270&page=1 I think they will rub. A leveling kit will help but there still going to rub.
Old Oct 6, 2009 | 03:33 AM
Dr Donut's Avatar
Dr Donut
i put 3" coil spacers on my truck and im runnin 35's and they only rub at extreme turning angles never in normal driving though
