High idle and no temp reading
Old Apr 14, 2026 | 11:50 AM
  #21
DerTruck's Avatar
DerTruck
Originally Posted by Nkirby2002
everything on the sensor seems to add up and I checked the resistance which I believe is good at 2.36 when truck is cold
2.36 what ? The number doesn't make any sense, as you can see from the table the resistance is anywhere from 290 kOhms to 400 Ohms. If you indeed measure 2.36 Ohms with a cold engine the sensor is defective.
Old Apr 14, 2026 | 05:17 PM
  #22
Think that is the volts reading.
Old Apr 15, 2026 | 10:08 AM
  #23
Nkirby2002's Avatar
Nkirby2002
sorry for the confusion I was measuring in kohms so (2360ohms). the bigger issue is that the live data on my scanner stays locked at 145°F no matter what I do. I unplugged the sensor (which should show -40) and I jumped the pins with a paperclip (which should show 280+), and the scanner didn't move a single degree either way. I already checked continuity on the wires all the way back to pins 11 and 14 on the 50-pin ECM plug and they are solid.
Old Apr 15, 2026 | 10:09 AM
  #24
Nkirby2002's Avatar
Nkirby2002
sorry for the confusion I posted in kohm it’s 2360
Old Apr 15, 2026 | 12:29 PM
  #25
DerTruck's Avatar
DerTruck
Ok that makes sense, 2.36 kOhms is 145F in the table. What doesn't make sense is that you measured that with a cold engine. Depending on your ambient temperature it should be around 10k Ohms. Do you still have the old temp sensor for comparison ?
As for the temp reading not updating, the ECM sends data to the PCM which in turn makes it accessible via OBD2. That might not be instantaneous or only when the engine is running, maybe a diesel owner can chime in here. Or you could check if the intake air temp sensor behaves the same.
