PS pump replacement
I just noticed a lot of oil around the PS pump.
At over 226k I guess it’s time to change it.
I take it I’m better off with a “new” unit rather than a “reman”?
Anything in particular I should avoid or recommendations on units you’ve had good experiences with.
Last time I went for a power steering pump, I tried three different pumps, from three different brands my local parts store carried, two of them howled worse than the pump I was replacing, the third one wouldn't even build any pressure..... The fourth pump, and actual Delco unit, (new) worked, but, even it was louder than I would have liked......
Oh, great… another crapshoot on getting a half decent part.
The beauty of owning an older vehicle.
I think I need to dig a little deeper on the actual problem.
The pump is quiet and works great… maybe I can get away with a front seal change.
Yeah, HeyYou says it's harder than you'd think. I've never personally tried it so I can't argue either way.
Eric the Car Guy has a great vid of tearing into a Sag pump. It was on a GMT400 but that matters not. I'd reco watching it.
