98 dodge ram 1500 trans noise
Old Oct 8, 2024 | 05:10 PM
eric29360's Avatar
eric29360
Default 98 dodge ram 1500 trans noise
i have a 98 dodge ram 1500 5.2L auto trans. when i start it up it idles fine but when i put into any gear it make a grinding noise (audio Attached )
i have no leaks and fluid level is good. please help
File Type: mp3
Old Oct 8, 2024 | 09:38 PM
That sounds like the pump is failing.... Whats you fluid look like? Is the trans full??
Old Oct 9, 2024 | 08:23 AM
Kchest08's Avatar
Kchest08
Mines is doing the same thing I will be on standby until we can figure this out.
Mines is a 2001 5.9 1500 2WD.
it sounds likes a pump is failing or a reservoir is empty. I checked all of reservoirs and everything is full. Any suggestions on the which pumps we should be looking for? I have also been considering replacing the drive shaft.
last thing, the oil gauge is stuck at 3/4 full.I’ve only have the car for about 5-months. So, only 2-oil changes have been done on this truck and the needle does not moved.
Old Oct 9, 2024 | 09:50 AM
Don't just replace the pump, rebuild the whole trans, otherwise, you will be right back in the same position in a couple days/weeks.
Old Oct 10, 2024 | 12:12 AM
eric29360's Avatar
eric29360
fluid is good
Old Oct 10, 2024 | 12:13 AM
eric29360's Avatar
eric29360
looks kinda chocolately
Old Oct 10, 2024 | 08:19 AM
Fluid looks 'chocolatey'??? That is not a good sign.... It's burnt.
