2001 ram 2500, 340 code
Old Nov 18, 2024 | 09:31 PM
2001 The Mayor's Avatar
2001 The Mayor
Default 2001 ram 2500, 340 code
I have a 2001 ram 2500 360 v8, it has left me standed 3 times by not fireing, after 30 to 45 minutes of trying, it starts, it comes up with 340 code on dash, looks to be cam sensor comunication , is it a bad cam sensor? Or wiring problem? Any help would be greatly apprecative! I just recently joined here, i have 3 2nd gen ram trucks, they been so great, tough and reliable up until this one
Old Nov 18, 2024 | 10:45 PM
AtomicDog's Avatar
AtomicDog
Good question. Could be either wiring or the sensor. Should be able to test the sensor to see if it shows up bad or not and/or continuity test for the wiring..
Old Nov 18, 2024 | 10:53 PM
DerTruck's Avatar
DerTruck
P0340 is a circuit code. With the problem resolving after some cooldown I would think it's the sensor itself though. It's similar to the issue in the video I linked this thread: https://dodgeforum.com/forum/2nd-gen...overrated.html
Old Nov 19, 2024 | 06:30 AM
Moparite's Avatar
Moparite
P0340 No Cam Reference Signal at PCM
Time to replace it.
Old Nov 19, 2024 | 10:32 PM
2001 The Mayor
Default Rotor froze on distributor
Took everybodys advice, bought cam sensor/ coil pickup. Took disrtbutor cap off, rotor wont come off, tried prying it of broke part of it, anyone run into this? Please tell me i dont have to remove intake manifold to access distributor, this wa my only running ram, other 2nd rams in need of repairing, need help, and need it to go to work,
Old Nov 19, 2024 | 10:56 PM
The rotor can get a pretty good grip on the distributor shaft. If it's already broken, just break it some more till it comes off.
Also, if it is hanging on that tight, that implies its been there for a while.... and you might consider replacing the cap and the rotor.....
