Frame Repair
Old Dec 7, 2024 | 07:13 PM
2pfspiff's Avatar
2pfspiff
Default Frame Repair
After taking my 96 ram 1500 club cab 4x4 in for an alignment, I was notified that there was a hole in the frame in front of the steering box.
Thankfully my friend is a welder and a boiler maker at work. So after tracing out the frame and then prepping it for repair.
He made the replacement pieces out of 3/16th plate and welded them in place.
There is still one more small patch to make, but the truck is safe to drive now. Probably will need to make a sway bar spacer for the other side, but that will be for another day.
Old Dec 7, 2024 | 10:22 PM
Keith_L's Avatar
Keith_L
Terrible lighting but awesome!
Old Dec 7, 2024 | 10:45 PM
2pfspiff's Avatar
2pfspiff
Lighting in my buddies shop is pretty bad and I think I have the flash off on the phone. Thanks. It was all him. I was there to learn.
Old Dec 8, 2024 | 10:10 AM
Keith_L's Avatar
Keith_L
I work on a 2000 that spent a bit of its life in PA and is similar but not as bad. The bigger concern is the inboard wall of the frame under passenger door.
Old Dec 8, 2024 | 10:11 AM
2pfspiff's Avatar
2pfspiff
I’ll take a look in that area. I did a quick scan when I was told about the front, but did not see anything.
Old Dec 8, 2024 | 10:52 AM
Moparite's Avatar
Moparite
When the factory made these frames they made a "cup" by the steering box. There is a hole near it and water splashes in and the "cup" holds it. What where they thinking? Could have at least put a drain hole there.
Old Dec 9, 2024 | 08:59 AM
2pfspiff's Avatar
2pfspiff
I checked the passenger side frame rail and it is solid. Just some surface rust. I thought the passenger side was going to need to be done, but after some cleaning it appeared to have a mouse nest in the frame.
Old Dec 9, 2024 | 09:11 AM
OK, that's different......
I once inherited a kitten that found it's way into a chevy truck fender.....
