Catalytic converter delete
Old Dec 14, 2024 | 04:24 PM
RamLife's Avatar
RamLife
Default Catalytic converter delete
Request any information on deleting the Cat/Con on my 1998 Ram 1500 5.2. I live in Florida which does not require emission testing. It has 184k miles. Oxygen sensors are on exhaust manifolds.. Runs great. Daily driver.
Has anyone done this?
Old Dec 14, 2024 | 07:43 PM
Spillage's Avatar
Spillage
Use a plug saver on the downstream O2 sensor.
New had any issues.
Old Dec 15, 2024 | 02:11 PM
RamLife's Avatar
RamLife
New had any issues.
Appreciate your response. Yet, did you mean never and not new?
Old Dec 15, 2024 | 03:02 PM
Los_Control's Avatar
Los_Control
I have done this just a few days ago ... no official report if it is a good or bad idea.
I was able to just remove my cat and then using a pipe and hammer just remove the guts probably should wear a mask for that. Then I installed the cat back on and is just a empty metal shell but no leaks.
I have a 1991 chebby truck also, it had the cat removed and they replaced it with a piece of pipe and it leaked and was loud .... I took it to a shop and had them weld in a pipe so no more leaks. ..... That was over 8 years ago.
Not saying is good or bad, just that it is a common practice.
FWIW, I have a 1993 Caravan with a 3.3 V6 and the car has 188K miles on it ... my exhaust was plugged and that is why I gutted my cat .... It still was plugged after that.
Then I removed the resonator and the exhaust is no longer plugged.
I would have bet $$ it was the crap from the cat went into the muffler and clogged the muffler. .... I had to remove the resonator anyways to get to the muffler .... I was surprised it was the resonator causing the issue.
A quick google search shows it is not as common as a cat but it does happen .... something to think about.
