No bus
Old Dec 25, 2024 | 05:16 PM
Hm2(FMF)Barnes's Avatar
Hm2(FMF)Barnes
Default No bus
My 99 ram 4x4 Cranks but no fire someone help please. I rebuilt the transmission put it in truck drove great but wouldn’t shift into overdrive so I unplugged to the transmission eight pin. The truck died and hasn’t started since my odometer says no bus. I’m pulling my hair out please someone help.
Old Dec 25, 2024 | 07:17 PM
AtomicDog's Avatar
AtomicDog
Typically, that sounds like a broken crank sensor. Many times, the crank sensor gets damaged if it's left on the engine block or is hanging dangling on it's wiring harness during a transmission removal/installation...
For the 'no bus' issue, you can check the fuse that controls the power to the OBD2 port or check some of the many YouTube videos that discuss solutions for the 'no bus' issue.
Old Dec 25, 2024 | 07:19 PM
Keith_L's Avatar
Keith_L
So, just to clarify, it was running and driving but no OD?
Then you unplugged the transmission connector, plugged it back in, and now you have a no start condition combined with NO BUS?
Old Dec 25, 2024 | 10:24 PM
Hm2(FMF)Barnes
Yes after installing the tranny it drive good but wouldn’t shift into overdrive but it ran and drove in trying to figure out the overdrive I unplugged the transmission 8 pin, it died and hasn’t started since also says no bud but it didn’t show no bus before.
Old Dec 25, 2024 | 10:31 PM
Hm2(FMF)Barnes
Old Dec 25, 2024 | 11:01 PM
Keith_L's Avatar
Keith_L
Hmm, very odd. I feel like the truck should run even if the trans plug were disconnected...? @DerTruck any wisdom here?
Old Dec 26, 2024 | 08:33 AM
Unplugging the trans should have zero effect on the engine...... I suspect that is just a coincidence, and not cause and effect.
See what you are missing. Do you have spark? Do you have fuel pressure? Getting injector pulse?
Old Dec 26, 2024 | 05:30 PM
Hm2(FMF)Barnes
I don’t know how to check for injector pulse but there isn’t spark, it’s getting fuel because you can smell it after cranking for a minute
Old Dec 26, 2024 | 05:32 PM
Hm2(FMF)Barnes
Is there a ground wire I could’ve missed I’m not sure if this is connected but I changed the bumper to a different style I have no ideas
Old Dec 26, 2024 | 07:01 PM
I would be havin' a look at the crank sensor.
