Losing traction in rear wheel off pavement. Need help.
Torque usually goes to the right rear wheel. An open differential will spin that wheel unless the left loses all traction. Then it goes to where the least traction is. One thing I noticed was you plan to do a water pump and stop a leak at the timing cover. Since you have to pull the water pump and harmonic balancer to fix that, 95% of the work is done to change the timing chain. A new chain can reall wake an engine up. Slap a new thermostat in there with the factory 195 setting and you'll probably appreciate the better heat you get from the heater.
Thanks for the wise advice ol' grouch. The water pump job was part of the list of things I've already done. Part of the rehab of this old van getting it ready to do some long overdue boondocking once I get this traction problem solved. Boondocking requires getting off the pavement so I really need to know I can get off and on the roadway in the Arizona dirt
. The advise from this forum has been educational and I think I'm getting close to what I'm hoping for.
You can't. Every rear you find with factory limited grip will have worn clutches. It will do nothing. Even when new they're imperceptible. Sorry, but it's true. Some enjoy the placebo effect of thinking they have a TAD (traction aiding diff) but that's as far as it goes with CrapLok. Again, sorry but reality is reality unless you think a CrapLok can identify as something that actually helps
Something like a TruTrac or Auburn would be awesome.
You're ahead to call a 4x4 or hot rod shop and ask them to install a real TAD. Somewhat related, from way back in '06
https://dodgeforum.com/forum/2nd-gen...oblematic.html
The next five responses will be from people telling you I'm wrong, so as with anything in life you get to choose who you believe. Good luck!
That's probably your cheapest option but swapping differentials is not really for the feint of heart... however, there's plenty of good Youtube videos on this! I've already started down this path myself to swap in a TL LSD.
While pulling a TracLoc out of a salvage yard 9.25 rear and adding clutches to it 'might' be the cheapest option, you also have the labor of swapping out the clutches in the LSD and labor for setup of the new LSD carrier in the existing rear axle of the van.
Swapping to a good limited slip rear from a salvage yard is likely the easiest and cheapest way to do the swap in my opinion. I had to swap my drum brake Dana 60 to a disc brake Dana 60 rear axle a few years ago. The swap did entail brake bleeding, installing the new disc brake style parking brake cables, swapping the speed sensor and new U-bolts, along with torquing those U-bolts to spec with a torque wrench. I also filled the new rear axle with gear oil and friction modifier for the limited slip unit.
Regarding the lunchbox...when you say delay? Is it something that affects normal drivability?
Lockers can take a bit to engage when they sense wheelspin, and some of them can be pretty harsh..... One of the reasons I like the clutch type, or helical gear LSDs. Granted, it isn't much of a delay..... but, if you are generous with your right foot when you have one tire spinning, and thumps pretty hard. If you ease into it though, not nearly so bad.
