P0505 code will not stay off
Old Jan 22, 2025 | 06:36 AM
Bam423's Avatar
Bam423
Default Code p0505
Originally Posted by Bam423
so unfortunately it didn’t work code came back in after 2 hours so pcm it is
I added a used pcm check engine light code came on bt it wasn’t the p0505 now it’s reading an 02 sensor I’m replacing here soon will update u guys and let u know what happened at least that p0505 is off 🤦🏽‍♂️
Old Jan 28, 2025 | 02:40 AM
Bam423's Avatar
Bam423
Default Added used pcm
so I added a used pcm right off the back the o2 sensor up stream heater 02 says it’s bad I added stand new Bosh and check engine light came on immediately after clearing the code I thinking on going back to the old con and c what’s going on I’m losing hope
Old Jan 28, 2025 | 06:58 AM
These trucks really don't like Bosch O2 sensors......
Where did you get the PCM from? Might take it back, and see if they have another....
Old Jan 29, 2025 | 03:32 PM
Bam423's Avatar
Bam423
it was a walker o2 sensor I got the pcm from a wrecking yard I called dealership and they said they discontinued making those for the 2nd gen I out old computer back and the iac check engine light came on when I out the junk yard computer in its goes to the 02 sensor saying it’s bad clear the code come back on almost immediately when start up should I swap out the pcm again or?? The junk yard pcm whe replacing the o2 sensor I replaced with new one check engine light came on I drove it let file get hot no solution
Old Jan 29, 2025 | 07:09 PM
If you weren't seeing the codes until you installed the junkyard PCM..... I would suspect the PCM.....
Old Jan 29, 2025 | 07:12 PM
Bam423's Avatar
Bam423
so the pcm that I had a friend pull for me was from a 2wd dodge so I have t go to pik n pull and pull a pcm from there my neighbor scanned it for me and a 47 number popped up the pcm isn’t sending a signal to the iac I’m guessing so pik n pull is my next stop then I’ll update !
