Dash bulbs not working
Old Feb 3, 2025 | 01:27 PM
Mdrenega's Avatar
Mdrenega
Default Dash bulbs not working
I tried to switch my old dash bulbs for some new ones, but some of them aren’t working. The bulbs are good, but I get nothing from when I plug them in. Does anyone know how to increase connectivity or how to get them working? The bottom left bulb isn’t working and now the left side of the speedometer isn’t working(not pictured)
Old Feb 3, 2025 | 03:41 PM
If you move the bulbs, do they work elsewhere??
Old Feb 3, 2025 | 05:24 PM
dodgetruck2's Avatar
dodgetruck2
if they're LED they quite often only work one direct, I had some cheap amazon LEDs once and they were terrible to get working, and they damaged the contact areas on the back I had trouble going back to OE bulbs even
Old Feb 3, 2025 | 07:55 PM
Moparite's Avatar
Moparite
You need to get the plug between the (194 i believe it is)bulb and the board. I looked into changing mine but haven't done it yet. And check the way you have them installed. Try turning them around to reverse the polarity. I assume they are led.
Old Feb 4, 2025 | 12:13 AM
Mdrenega's Avatar
Mdrenega
yes they are from Amazon. They are terrible at getting a connection. I’ve tried wiggling them. Turning them partially, turning them fully or just putting them in. Hopefully I didn’t damage my instrument panel. I ordered some dielectric silicone grease to hopefully improve connection at the connection point.
Old Feb 4, 2025 | 12:16 AM
Mdrenega's Avatar
Mdrenega
they are T10 194 LED Bulbs.
Old Feb 4, 2025 | 12:17 AM
Mdrenega's Avatar
Mdrenega
yes they do work elsewhere. I think it’s a connection issue. Someone at work recommended wrapping the bulb with a thin copper wire to help conduct better.
