need help wiring brake controler
Old Jan 11, 2006 | 08:10 PM
MiaTurbo's Avatar
MiaTurbo
Default need help wiring brake controler
Hello folks. My 99 Sport came with the tow package, but the P/O never installed a brake controler. The harness/adapeter was in the glove box, but I don't know which wire is which. Off of the connector, there isa black wire, white with orange stripe, light blue, and red w/black stripe.
The controler's wiring is: black:12+, Red: brake switch, white: 12-; and blue: trailer connection.
It would be too easy to assume that the colors match up. I appreciate your help. I'm picking up a trailer for the track car this weekend, so I need to make sure it's in order before I head up.
Old Jan 12, 2006 | 12:11 PM
ASH's Avatar
ASH
Default RE: need help wiring brake controler
Match the colors, it is that easy. If you are not sure, use a test light to double check. Attached is a link to check the plug.
http://dodgeram.org/tech/mods/electric/trailer_wire.htm
Old Jan 12, 2006 | 12:33 PM
CODODGE1500's Avatar
CODODGE1500
It depends on the brake controller! Some dont match colors. My Protogy brake controller did not match the colors. the best thing is to look at the directions
Gabe
Old Jan 12, 2006 | 01:29 PM
shott8283's Avatar
shott8283
get used to using a DMM... digital multimeter!
Old Jan 12, 2006 | 05:33 PM
ASH's Avatar
ASH
ORIGINAL: CODODGE1500
Gabe
[sm=bustedsign.gif] Oops. I thought they would be standardized. However, from what you wrote in your original post, I think that it is correct to match the colors. Black provides power to the controller, white is ground, red goes to the brake switch, and blue goes to the trailer, giving the power to brakes. If you are not sure, bug the wires together using electrical tape and check the plug at the rear of the truck using the link I gave earlier. If you are correct, then permanently connect the wires.
Old Jan 13, 2006 | 04:16 AM
ryans590's Avatar
ryans590
yes it should be black to black white w/orange stripe to white blue to blue and red w/black to red but you'll wanna check for shure
