No buss code on dash
Old Feb 28, 2025 | 04:52 PM
Bubba12's Avatar
Bubba12
Default No buss code on dash
Hey im Rob
im having issues with the my 2000 ram 5.2 it has a code on the dash saying no buss . Im just wondering if theres a way how to fix it
Old Feb 28, 2025 | 05:48 PM
Does it start and run? Drive down the road OK?
Old Feb 28, 2025 | 05:54 PM
Bubba12's Avatar
Bubba12
Yes it does the only thing is that it stays in third gear and I have the OD on and the trans temp on dash
Old Feb 28, 2025 | 08:56 PM
That can't be a coincidence..... Check the harness going to the trans, see if it got pinched somewhere. Also, check the connector at the trans, the wires like to pull out and short together.
Old Feb 28, 2025 | 09:10 PM
Bubba12's Avatar
Bubba12
I will check the sensors in the transmission tomorrow and what about the no buss code is that fixable?
Old Feb 28, 2025 | 09:13 PM
DerTruck's Avatar
DerTruck
You might also try disconnecting the connector at the trans to see if there's an internal wiring issue. The PCM disables overdrive if it deems the transmission too hot and if the temp sensor is shorted it might cause the CCD bus to go down as well.
Old Feb 28, 2025 | 09:15 PM
No bus simply means that the cluster isn't getting any information on the communications bus. Unfortunately, EVERYTHING in the cluster is driven by that bus. Most of the sensors are on it as well, so, if one fails in some fashion, it takes down the entire comm bus, and things stop working. Like your transmission. I suspect that if you solve the trans problem, you'll solve the no bus as well.
Old Feb 28, 2025 | 09:22 PM
Bubba12's Avatar
Bubba12
Wow this is great information tomorrow i will get to it and by any chance, do you know how many sensors does the transmission have?
Old Feb 28, 2025 | 09:29 PM
46RE trans, so, the electronic are really rudimentary. Governor Pressure solenoid, Torque Converter Clutch Solenoid, and O/D solenoid all operate on 12 volts, with the PCM controlling them via the ground. Governor pressure sensor, output speed sensor (which is on the outside of the trans, and has it's own connector....) are the only ones I recall just off hand, governor pressure is internal to the trans, and includes the trans temp sensor, both are fed by the same 5 volt signal.... I suspect your problem is with that 8 pin connector. It's on the drivers side of the trans, and plugs straight down into the top of the valve body. (the wide part toward the bottom of the trans, above the pan.)
You can download the factory service manual for your truck from here, as well. LOTS of useful information in there, including wiring diagrams.
Old Feb 28, 2025 | 10:02 PM
Bubba12's Avatar
Bubba12
Alright thanks i will check the schematic on the transmission to see how everything works thanks for your time I appreciate it.
