42re behind 5.9?
Old Mar 5, 2025 | 08:26 PM
MtnTndra's Avatar
MtnTndra
Default 42re behind 5.9?
Hey doing a 5.2 to 5.9 engine swap but can't find the transmission id placard and evey time i search my truck up on Mitchell or prodemand it says i have a 42re. What I'm wondering is if dodge ever put the 5.9 v8 in front of the 42re and if not can I run it for a while until I get a 46re.
Old Mar 5, 2025 | 08:53 PM
It will likely bolt right to it, however, don't expect it to last long behind a 5.9. Also, keep in mind the 5.9 is externally balanced, whereas all the other engines were internal balance, so, you'll need a flexplate for a 96 and up 5.9, else it won't bolt to your torque converter.
Old Mar 6, 2025 | 05:47 AM
Moparite's Avatar
Moparite
Keep in mind there where changes depending on vehicle and the year of the trans you want to put in.
Old Mar 6, 2025 | 08:09 AM
dodgetruck2's Avatar
dodgetruck2
This is more a curiousty question of my own, what are you swapping. I never knew a 42RE came behind a 5.2, I thought all applications were a 46RE year respective of course.
Old Mar 6, 2025 | 09:36 AM
AtomicDog's Avatar
AtomicDog
I'm pretty sure I have a 42RE behind a 3.9 V-6 in a '96 Dodge Dakota I'm working on to sell soon...
Old Mar 6, 2025 | 11:33 AM
adukart's Avatar
adukart
The dakota/durango 5.2 variants had the 44re, which was a little lighter duty than the 46re but had a better 1st and second gear ratio.
Edit: saw your other thread. A 1999 ram 1500 5.2 should have a 46re. You can always get a build sheet here with your vin: https://fcagroup.my.site.com/RAM/s/equipment-listing
Old Mar 6, 2025 | 06:57 PM
dodgetruck2
This is the part i was referring, I'm not familiar with Durango's and Dakotas so much, but to my knowledge all v8 ram trucks had the 46RE/RH only
Old Mar 7, 2025 | 10:07 AM
That was my thought as well. Did the six cylinder variants come with the 42, or 44??
Old Mar 7, 2025 | 06:54 PM
Moparite's Avatar
Moparite
42RH/RE "Introduced in the 1988 model year on a limited basis, it was the first light-duty Chrysler four-speed automatic and was placed behind the 3.9 L and 5.2 L engines for light-duty purposes.".
Probably more here than you want read. It was not the only trans the V6's used. Interesting though, Found out that 1978 was the first year the 727's had lock up converters. I always heard about it but didn't know if it was fact. Seems this was for the cars and not the trucks. I know my 78 Power Wagon does not have it.
Old Mar 7, 2025 | 07:56 PM
dodgetruck2
I wonder if that was full run of the 5.2? makes me want to crawl under my 98 now. Seems strange as I'm positive my 01 Dakota with the 360 has a 46re, why would a Dakota have a beefier trans than a 1500
