2000 rear driveshaft
Old Mar 6, 2025 | 10:07 PM
Toledo ram's Avatar
Toledo ram
Default 2000 rear driveshaft
I have a 2000 Dodge ram 1500 4x4 single cab auto trans wheel base is 119 bed is the 6.6 box.....what years rear driveshaft can I use? I been to the local pick a part yard and came across a 1997 ram 4x4 single cab auto trans that has the rear driveshaft attached still for now...it was only a half inch longer than the one that's on my truck.would it work ?
Old Mar 7, 2025 | 10:04 AM
Why do you need to replace it?
Old Mar 7, 2025 | 10:27 AM
Toledo ram's Avatar
Toledo ram
Old Mar 7, 2025 | 10:31 AM
OK, that's a good reason.
Are you actually IN Toledo?? If so, check out Toledo Driveline and Gear. They can make you one for not too bad of a price.
Old Mar 7, 2025 | 06:00 PM
Moparite's Avatar
Moparite
If the shaft is ok you can get new yoke/s welded on.
