Ram1500
Old May 1, 2025 | 12:45 PM
RROSE95's Avatar
RROSE95
Default Ram1500
My Dodge ram pickup won't stay running when I start it immediately dies out only runs if I hold the acculator pedal and has a code 25 check engine light can some tell me actually what that code is for
It's a Dodge ram 1500 ,1995,,5.2 engine
Old May 1, 2025 | 01:31 PM
AtomicDog's Avatar
AtomicDog
What year truck and what motor + transmission? Code 25 "might" be related to the idle air controls or a vacuum leak...
Old May 1, 2025 | 03:06 PM
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
Yup. Either the port in the throttle body is clogged with junk, the IAC itself has failed, or the PCM has.
