Mystery plastic under valve cover
Old May 12, 2025 | 08:40 PM
I am leaning toward a bad lifter..... but, not sure that would restrict oil flow to the rocker.... Could measure how far the rocker moves, and then compare that to another one.... See how much difference there is.
Old May 12, 2025 | 08:59 PM
CarsRam1997's Avatar
CarsRam1997
I’ll have to get a dial indicator and see
Old May 12, 2025 | 10:12 PM
Moparite's Avatar
Moparite
These are not supposed to be under the valve cover! They are to keep the wire harnesses in place. They are taped to the harness and after the valve cover is on they go on the stud to keep them in place.
Old May 12, 2025 | 10:30 PM
dodgetruck2's Avatar
dodgetruck2
I was also going to mention, those look like the engine harness holder clips that go on the valve cover studs
Old May 13, 2025 | 06:06 AM
CarsRam1997
That makes a lot more sense. They must’ve fell in when I resealed the valve covers a couple thousand miles ago, the same time I did the plenum plate. It still had a rattle from the valve cover before I did the reseal, and also still had a misfire before.
Old May 15, 2025 | 08:51 AM
Keith_L's Avatar
Keith_L
Those can be a huge PITA to pry off their respective studs. Honestly, be glad they're gone.....but be less glad if they were living inside the vc
