Check the slave cylinder, that it's mounted correctly. Not familiar with clutches on these trucks, but in general if the rod that pushes the clutch fork is misaligned, it could cause described situation.
Well it sounds like he's saying the pedal won't depress at all, so I guess I'd classify that as quite firm
But I don't know what would cause this except for a bound-up fork or throwout.....?
I couldn't decide, he says he's pushing it in so to me this means the pedal is moving but the clutch isn't releasing. There's no way stock, to visibly see the clutch move
