Lack of power and Gas Mileage.
Old Jul 12, 2025 | 05:06 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Lack of power and Gas Mileage.
Now I know these trucks don't get good gas mileage. But here is the thing, is a Sport ORE with 4.10s it's not only allowed then my 2500 with 37s and 3.55s but it also gets worse (2500-12mpg, this one 6mpg) than my 2500.
I did the plenum, tune up, and timing chain. It just feels sluggish.
Old Jul 12, 2025 | 09:35 AM
Should be able to do better than 6....... Something else is going on there. How old are the O2 sensors? Cat plugging up?
Old Jul 12, 2025 | 01:17 PM
DerTruck's Avatar
DerTruck
The engine might be running super rich. Look at the temperature and O2 sensor readings, they might give a hint.
Old Jul 13, 2025 | 06:05 PM
ol' grouch's Avatar
ol' grouch
Check your vacuum. You should be pulling 17 inches of mercury, more or less. If it's low, you might have a collapsed catalyst or rusted internally muffler. Unless you live near fields in which case you might have mice nests in the tail pipe. It could be other things but I'd check those first.
Old Jul 13, 2025 | 06:50 PM
MoparFanatic21
I did check them. They turned out to be good. I did get an evap large leak code
Old Jul 13, 2025 | 06:51 PM
MoparFanatic21
I will have to look into that, although vacuum seems to be good
Old Jul 17, 2025 | 06:02 AM
MoparFanatic21
Here is the scan data. Only thing I noticed if fuel trims are high and the rear O2 sensors is only fluctuating 0.20ma.
Old Jul 17, 2025 | 08:57 AM
Wow. That's adding a LOT of fuel...... How old are the O2 sensors??
Old Jul 17, 2025 | 10:41 AM
ol' grouch's Avatar
ol' grouch
I had a car once that the fuel mileage tanked. I mean serious tanking. It went from 21 mpg to 8. There was a problem with one rear brake dragging the parking brake. You can check your wheels with a remote thermal thermometer and see if one is extra hot.
Old Jul 17, 2025 | 05:19 PM
MoparFanatic21
I had that problem on my 3500 someone over tightened the emergency brake and it was dragging lol. Forgot about that, will have to look into that
