2001 Dodge Ram 2500 w/5.9 crank no start
Old Jul 28, 2025 | 08:01 PM
LTGEddie's Avatar
LTGEddie
Default 2001 Dodge Ram 2500 w/5.9 crank no start
I have a 2001 5.9 2500 dodge ram vin z. It was driving fine before I got into an accident. I hit a car in front of me and the truck turned off on me and it would crank no start. It got towed home inspected fuses, fuel pressure, ignition coil and i got no spark from distributor to spark plugs. I inspected the distributor cap and saw it was broken, upon replacing it I noticed the order on the cables was wrong so I fixed the sequence. What once started on out of order cables is now a crank no start. So my next thought was check the distributor since the cables were out of order maybe the distributor is bad, and I had an ongoing issue before where the truck would die on me and not want to start again, and then it would. So I O scoped the camshaft sensor and it was bugging out and not reading anything so I replaced the distibutor and now it does the same thing. Crank no start. Can someone please point me in the right direction.
Old Jul 28, 2025 | 09:01 PM
How much front end damage?
Moving this to second gen ram section for ya.
Old Jul 28, 2025 | 09:23 PM
LTGEddie's Avatar
LTGEddie
wasn't even that bad tbh just a little bend to the chrome bumper. Ill attach a photo
Old Jul 28, 2025 | 09:35 PM
Wonder if someone did something with the distributor before..... Probably wouldn't hurt to verify base fuel sync..... Turn the engine so number 1 is at TDC, in the firing position, the distributor rotor should be pointing at the notch in the distributor body. ( if you are laying on the engine, it'll be at 7 O'clock or so....)
Old Jul 28, 2025 | 09:57 PM
LTGEddie's Avatar
LTGEddie
I changed the distributor rotor and cap. When I pulled it out someone was definitely in there doing god knows what. They had used silicone to make the gasket.
Old Jul 28, 2025 | 10:11 PM
There isn't a gasket that I am aware of.....
Old Jul 28, 2025 | 10:45 PM
LTGEddie's Avatar
LTGEddie
Sorry I meant the o ring
Old Jul 29, 2025 | 09:30 AM
Didn't think there was an o-ring either.
That said, some folks will seal the distributor if they do a lot of off-road driving, and water crossing....
Old Jul 29, 2025 | 01:04 PM
LTGEddie's Avatar
LTGEddie
Okay that would make sense lol any idea as to what I should check?
Old Jul 29, 2025 | 03:07 PM
Need to find out what's missing. Spark, or fuel.
