Oil pressure & running hot
Old Jul 29, 2025 | 07:13 PM
Bluedevilish96's Avatar
Bluedevilish96
Default Oil pressure & running hot
Hello everyone, I just got my plenum gasket done as I was out of town for work & figured it was the perfect time for me to avoid doing it lol. Well after the fact I’ve driven it about 250 miles and have noticed idle/no throttle cruising im about 20-30 psi oil pressure & w/ throttle is 40 psi. I also have noticed under zero load the motor is strong at 200 degrees, but depending on the load it varies from 205-230. I only ask because before I had it done the motor never left 40 psi & temp never left 200. Are these normal ? The temperature definitely feels pretty hot to me, and the coolant is at the accurate level
Old Jul 29, 2025 | 08:49 PM
Oil pressure behavior is pretty normal. Bear in mind, the gauge isn't the most accurate thing in the world......
As for Temp though, I would check the connection on the temp sensor, and make sure it's good, clean, and tight. If yours is indeed a 96, then you will have TWO temp sensors. Two wire sensor for the PCM, and a one-wire sensor for the gauge.
Old Jul 30, 2025 | 12:42 AM
AtomicDog's Avatar
AtomicDog
As part of the plenum gasket upgrade, did you change the thermostat, water pump or anything else?
Old Jul 30, 2025 | 02:50 AM
Moparite's Avatar
Moparite
You didn't say how many miles you have or what weight oil you are using.
