Ac compressor clutch not engaging
Old Aug 2, 2025 | 08:09 PM
dodgetruck2's Avatar
dodgetruck2
What are your pressures? some cycling is acceptable based on operation of the system, but if it ran and shutoff and never ran again, I would guess you are low or high on fill level
Old Aug 2, 2025 | 08:22 PM
Cody.wickliffe's Avatar
Cody.wickliffe
It’ll run then switch off then turn back on 5-10 secounds later
Old Aug 2, 2025 | 08:24 PM
dodgetruck2
Id measure temp at the vents, doesn't sound to abnormal to me
Old Aug 2, 2025 | 10:11 PM
No, it doesn't. Insufficient charge would be my guess. At idle, on a reasonable day, (around 70, or above) the compressor should run constantly. Put some gauges on it, see what they have to say.
