Ac compressor clutch not engaging
Old Aug 1, 2025 | 10:23 PM
Cody.wickliffe's Avatar
Cody.wickliffe
Default Ac compressor clutch not engaging
Got a 1998 dodge ram 1500 replaced all the ac components hi low switches too and the clutch won’t engage got it full of freon and everything no fuses blown or anything anything too point me in the right direction would be greatly appreciated
Old Aug 1, 2025 | 11:03 PM
dodgetruck2's Avatar
dodgetruck2
is there power/ground at the clutch? i believe its controlled by the PCM, could be a computer issue
Old Aug 1, 2025 | 11:10 PM
Cody.wickliffe
I’m able to jump the compressor but beside that it doesn’t engage on its own
Old Aug 2, 2025 | 09:40 AM
Straight6's Avatar
Straight6
Is there a connection problem at anything you replaced?
Old Aug 2, 2025 | 09:47 AM
Grab the service manual for your truck from here. Wiring diagrams are in section 8W. Verify the circuits controlling the a/c. See what's missing.
Old Aug 2, 2025 | 10:16 AM
dodgetruck2
A/C clutch is powered by the A/C relay in the PDC, the relay is powered by Fuse 11 Run/Start and grounded by the PCM.
Being as its controlled by the PCM you have multiple factors involved. It appears the HVAC control sends two signals to the PCM one to request A/C and the second to pass through the high/low switches for safety sense. HVAC control is powered by fuse 5, however if your mode/blower selections are working, the HVAC control is powered just fine.
Old Aug 2, 2025 | 11:07 AM
Moparite's Avatar
Moparite
Have you checked the pressure switches for continuity? If the pressure is to high or low(depending on how much freon you put in) you won't have continuity and the system won't have a complete circuit and won't come on.
What did you replace?
Old Aug 2, 2025 | 06:03 PM
Cody.wickliffe
So I replaced all the hi low switch and since yesterday the compressor has kicked on but a few seconds after it shuts off now the cold line has a point which one half cold the other not cold as shown in the picture would this be enough to restrict the flow
Old Aug 2, 2025 | 07:56 PM
dodgetruck2
That's your orifice tube and its exact job is to restrict, one side sweating and one side not sounds like its functioning perfect
Old Aug 2, 2025 | 07:57 PM
Cody.wickliffe
Well that’s good to know now that leave the ac compressor clicking on and off
