99 1500 manual drivers side door latch
Old Aug 5, 2025 | 08:30 PM
dslywalker's Avatar
dslywalker
Default 99 1500 manual drivers side door latch
I've been trying to find one, but they seem to be hard to find. There's plenty of electric ones, so question is will a electric one fit where a manual used to be.
I've seen some used ones but they were working when i took it out scares me..Lot of work and cut hands to get them in.
Has anyone tried to repair one that broke one. One of the levers that operate the opener function is internally bad.
Or if you know of any place to buy one can you please let me know..They seem to be scarce as hen's teeth
Mike Flynn
99 dodge ram 1500 3.9 5spd
Thanks for your time
Old Aug 5, 2025 | 08:57 PM
I come up with 55076291, but, that's with electric locks. It *looks* like it should work anyway..... as all the manual linkages are mechanical..... Not just a switch that triggers the electric lock..... in the neighborhood of 60 bucks for new OEM parts.....
Keep in mind, I don't think I have ever seen a latch fail..... without the door it was bolted to also having some issues......
Old Aug 5, 2025 | 10:49 PM
dslywalker's Avatar
dslywalker
i put a new handle assembly on the outside of the door because you could feel it was ready to go. Well that didn't help, you could open the door on the inside but not the outside.
It was shutting properly,so popped out the plug and you could see the lever move but wasn't doing anything. So i took it out and thought about taking it apart but figured couldn't get the part anyway.I'll look at that part number..Some sites were selling electric ones as a pair for 40- 60
Thanks for your help
Old Aug 6, 2025 | 06:36 AM
Moparite's Avatar
Moparite
LMC truck has em.
Old Aug 8, 2025 | 12:59 AM
dslywalker's Avatar
dslywalker
Thanks a lot Moparite amazing they didn't turn up in a Google search.
They sure like to charge .I bought some wiring diagrams from them ouch they were pricey too
If yah got to have it, you to have it.Yah got pay the price
Thanks again for your help Moparite and HeyYou
