Carbs blowing air out the top
Old Aug 9, 2025 | 06:13 PM
Cody.wickliffe's Avatar
Cody.wickliffe
Default Carbs blowing air out the top
Need some help figuring out why my trucks throttle body’s blowing air out the top when you start it up or when it revs up too move
Old Aug 9, 2025 | 06:16 PM
Does it run all right otherwise?
Old Aug 10, 2025 | 08:15 AM
Cody.wickliffe
Yeah but it’s loud and not quite the right sound you want to hear from a motor you pour your time into
Old Aug 10, 2025 | 08:19 AM
HeikIlm's Avatar
HeikIlm
What's done to it?
Old Aug 10, 2025 | 08:21 AM
Cody.wickliffe
I put all new gaskets on it and fixed all the vacuum leaking got the ac blowing ice cubes and when you start it up it makes the sound and like if it revs up too drive
Old Aug 10, 2025 | 08:24 AM
At startup, the engine should flare to about 1500 rpm, then settle slowly back to around 650-700 at idle. Does it do that?
Old Aug 10, 2025 | 08:25 AM
Cody.wickliffe
It does flat up and idle back down
Old Aug 10, 2025 | 08:26 AM
Is it actually blowing out? Or is it sucking in???? Is the throttle body nice and clean?
I 'expect' some noise from it, when IAC is open..... get a fair bit of flow noise there, but, most of that should be muffled by the filter housing.....
Old Aug 10, 2025 | 08:27 AM
Cody.wickliffe
Oh it blows out probably more than it takes in
Old Aug 10, 2025 | 08:29 AM
Then you either have a cam timing issue, or a clogged cat..... clogged cat would leave the engine WAY down on power.......
