Dash cluster
Old Aug 11, 2025 | 06:42 AM
Moparite's Avatar
Moparite
Try this and see what you have.
Old Aug 12, 2025 | 06:35 AM
Usmarine9!'s Avatar
Usmarine9!
Nope didn’t work
Old Aug 12, 2025 | 10:08 AM
What didn't work?
Old Aug 12, 2025 | 10:11 AM
Usmarine9!'s Avatar
Usmarine9!
Nothing in the cluster works I tried to do the test but nothing works
Old Aug 12, 2025 | 10:12 AM
Time for a replacement then.
Old Aug 13, 2025 | 06:37 AM
Usmarine9!'s Avatar
Usmarine9!
Will do
Old Aug 15, 2025 | 06:26 PM
DerTruck's Avatar
DerTruck
Does the parking brake indicator work (ignition on) ? Instrument cluster lighting ? High beam/turn signal indicator ? They are independent of the electronics in the cluster. Also, did you check fuse 14 in the interior fuse panel ? As already suggested, pull out the cluster and check the connectors at the back before springing for a "new" cluster.
