Dash cluster
Old Aug 10, 2025 | 12:01 PM
Usmarine9!'s Avatar
Usmarine9!
Default Dash cluster
None of the gauges are working I’ve checked all the fuses in the door jam and they are good. I’ve looked under the dash and don’t see anything obvious. It starts and runs.
Old Aug 10, 2025 | 12:09 PM
HeikIlm's Avatar
HeikIlm
What's your vehicle?
Old Aug 10, 2025 | 12:14 PM
Usmarine9!'s Avatar
Usmarine9!
2001 ram 318
Old Aug 10, 2025 | 12:15 PM
Do you get the no bus error in the odometer?
Old Aug 10, 2025 | 12:24 PM
Usmarine9!'s Avatar
Usmarine9!
No nothing
Old Aug 10, 2025 | 02:48 PM
Does the Odometer display anything? Or is it just blank?
Old Aug 10, 2025 | 03:02 PM
Usmarine9!'s Avatar
Usmarine9!
No it’s just blank
Old Aug 10, 2025 | 04:56 PM
That's weird. Does it test when you first turn the key on??
Old Aug 10, 2025 | 05:02 PM
Usmarine9!'s Avatar
Usmarine9!
l don’t know what you mean when you say test. It stays blank when I just turn the key on and remains blank after it starts
Old Aug 10, 2025 | 09:00 PM
That is not right.... It should at least light up all the elements when you first turn the key on...... Wonder if your cluster just died....... Could pull it, reseat the connectors, and see if it wants to start working.
