Alternator positive wire
Old Sep 6, 2025 | 03:21 PM
Deadlywolf36's Avatar
Deadlywolf36
Default Alternator positive wire
The positive wire coming from the alternator to the power distribution center has corroded and is failing I need to replace it but haven’t been able to find the gauge of the wire and could use some help. 2001 dodge ram Laramie slt 5.9 magnum
Old Sep 6, 2025 | 04:52 PM
Go to your local parts store, take the old one with you, get something the same size, or LARGER.....
Old Sep 7, 2025 | 12:07 AM
ol' grouch's Avatar
ol' grouch
Keep in mind, th gauge and size are inverse related. The smaller the number, the larger the wire. Think of it as how many to make a certain size. 2 2 gauge will be as thick a cable as 16 16 gauge.
Old Sep 7, 2025 | 07:41 AM
Moparite's Avatar
Moparite
Also the amp of the alternator and the length of cable play into it. A description here. I believe it is either 4 or 6 gauge. Most of the parts stores carry thinner gauge 10-18 so you may have to visit your local home improvement store. And don't forget the lugs.
Old Sep 7, 2025 | 01:50 PM
HeikIlm's Avatar
HeikIlm
Measured that cable on my '95 diesel, and it seems to be 3 AWG, according to diameter, which was roughly 6 mm.
Old Sep 7, 2025 | 03:12 PM
That seems really tiny considering the current it carries......
Old Sep 8, 2025 | 12:29 AM
ol' grouch's Avatar
ol' grouch
I don't know about that. 3 seems like an odd number. Usually you see 2 or 4 gauge. 2 gauge is some serious wire. Anything heavier and you have welding cable. I've got some jump cables that are 2 gauge.
Old Sep 8, 2025 | 07:04 AM
Moparite's Avatar
Moparite
Look at the chart in the link above, It gives you the gauge wire for amps and length. About a 5 foot run at 125 amps.
Old Sep 8, 2025 | 07:54 AM
dodgetruck2's Avatar
dodgetruck2
I thought alternator cables were around 6 gauge. Jump cables shouldn't be anything less than 2 gauge in my opinion, unless you're using them on a lawn mower
Old Sep 8, 2025 | 06:26 PM
ol' grouch's Avatar
ol' grouch
I had a pair of 30 foot jumper cables made out of welding cable. Heavy as lead but they worked great. At least until they grew legs and walked off.
