4wd issues
Old Nov 23, 2025 | 12:10 PM
Mneukirch86's Avatar
Mneukirch86
Default 4wd issues
2001 dodge ram 1500 4wd 5.9gas
so I’m having a bit of an issue I’ve noticed when I placed my truck into four-wheel-drive. I get a gear whine and a little bit of a hesitation and then it won’t easily go back into 2wd. And then when it’s in four-wheel-drive, it just doesn’t seem like it’s acting properly.
I did make sure that my fluids in my transfer case as well as my front differential are correct level as well as I change the fluid entirely in my transfer case with atf+4
And I checked my vacuum lines and from what I can tell, they all appear to be in good shape so I’m thinking it might be my vacuum actuator. What are you all think ?
Old Nov 23, 2025 | 12:29 PM
Does the 4x4 lite in the dash come on? If so, the vacuum system is working. It may take it a few seconds to engage, but, that's the nature of the beast.
A bit more noise if 4x4 is also normal.
Could you clarify 'doesn't seem like it's acting properly'? It WILL drive different in 4x4.... and if you try that on a high traction surface, yeah, that's gonna be interesting. (not a good plan.....)
Old Nov 23, 2025 | 12:33 PM
Mneukirch86
It seems to have a high gear wine, similar to how it sounds in low gear. Which I don’t recall being the same sound it used to previously. I found that I have to change it between neutral and 2 Wheel Dr. multiple times To get it to be able to disengage to go back into 2 Wheel Dr. It doesn’t automatically seem to go when you transition four-wheel-drive high to 2 Wheel Dr. high.
As for the four-wheel drive indicator light, it does turn on, but will also stay on in 2 Wheel Dr. on those times that it chooses to not disengage
Old Nov 23, 2025 | 12:34 PM
Is it difficult to shift? Or does the lite in the dash stay on for longer than you think it should?
Old Nov 23, 2025 | 12:40 PM
Mneukirch86
It does not seem to be difficult shifting, but the four-wheel drive indicator light does stay on in 2 Wheel Dr.
Even if I drive it around the block it’s still reacts like the four-wheel drive is still engaged even though the actual shifter is placed in 2 Wheel Dr.
Old Nov 23, 2025 | 02:10 PM
That just means the front axle is still locked. They aren't actually driving anything, and it probably does change the steering feel, but, if you drive in a straight line, and just kinda rock the steering back and forth a bit, it'll help it disengage. Also probably wouldn't hurt to check for vacuum leaks. Make sure you have good vacuum at the actuator, so it can work properly.
Old Nov 23, 2025 | 02:37 PM
Mneukirch86
Yeah, but that’s the thing like I would still have the gear whine and it would drive like it was in four-wheel-drive even though the shifter was placed in 2 Wheel Dr. and I would literally drive it around the block and it would stay that way until I had to move the shifter to multiple different positions and then eventually it would go back into 2 Wheel Dr. And it definitely never gave me this problem before. And then 2 Wheel Dr. I don’t have the gear whine
Old Nov 23, 2025 | 03:05 PM
If the front axle is still locked together, all that front driveline stuff is still turning, it just isn't powered, and front/rear are not locked together. You likely have a vacuum problem. Either a leak somewhere, and there are a LOT of opportunities for that.... a bad switch, or a failing diaphragm on the actuator. On my truck, the front axle will engage/disengage within a few seconds of moving the shift lever. Yours isn't. Vacuum problem.
Old Nov 23, 2025 | 04:02 PM
Mneukirch86
Thank you, I’ll go on the hunt
Old Nov 23, 2025 | 04:37 PM
Steel lines between switch and axle like to rust out. Either that, or collect moisture, and if it gets below freezing, no 4wd for you. (ask me how I learned that one......)
