98 Dodge Ram 1500 Compression test
Old Feb 18, 2026 | 03:09 PM
nalan9's Avatar
nalan9
Default 98 Dodge Ram 1500 Compression test
Hello all, I have a 98 dodge ram 1500 5.9L and would like to run a compression test on it. I attempted it earlier today, but tested incorrectly. I didn't open the throttle, or remove the fuel fuse. I cant locate where the correct fuse is, can any one please help me locate it. And tell me if there's anything else I should be doing to run the test correctly.
Is it the circled one?
I tested #8, #6, and #4 before I stopped due to the weather. They were all extremally low, but the numbers were all consistent.
Thanks for any help that you can all provide!
Old Feb 18, 2026 | 04:31 PM
Numbers will be low if the throttle is closed.
Pull the fuel pump relay. Underside of the cover should show you which one it is.
Old Feb 18, 2026 | 04:43 PM
nalan9's Avatar
nalan9
I was looking at the underside of the relay, its orientation is confusing to me. I just want to make sure that I have the correct one!
Old Feb 18, 2026 | 08:07 PM
Go by the shape of the diagram, and the box. That makes it pretty easy.
