Transfer case wiring diagram
Old Mar 1, 2026 | 07:03 PM
PMWilson57's Avatar
PMWilson57
Default Transfer case wiring diagram
So boys and girls. put in a cable actuator because the vacuum one was fubar.. but still when I go into 4wd hi I get a god awful clicking like gears are trying to engage, in 4 lo range nada.. pulled my vacuum harness and its junk, does anyone think this is the issue, plus where does the Blue, red green, blac, gray connect to in the engine compartment, can not find the diagram? I really don't want to sell my truck, but I am tired of chasing this issue? 1997 1500 4x4 231 d transfer case, 46 re trans...
Old Mar 1, 2026 | 08:02 PM
Black line is vacuum source, should go to passenger side of the intake, one of the vacuum ports there. (it my just connect to the bag o' snakes over there too.) Green line is a vent. Just runs up behind the engine, doesn't connect to anything. Other two lines run up front to the cad. One to each port. But, as you don't have that any more, you can pull the whole thing, plug the spot it hooked to on the engine, and call it a day.
If you get bad grinding in 4 high, but not 4 lo, that is likely a mechanical issue in the t-case itself, prolly gonna have to pull it, and open it up to see what's going on.
Old Mar 1, 2026 | 09:23 PM
DerTruck's Avatar
DerTruck
Check the t-case shift linkage before starting major surgery.
Old Mar 2, 2026 | 10:14 AM
Keith_L's Avatar
Keith_L
The t-case controls front d/s. The vac controls CAD. With vehicle elevated determine if RF shaft engages in either 4wd position. Then determine if you can spin front d/s in P. If you can spin the d/s in 4hi or 4lo, the problem is linkage (external) or in the t-case (internal)
Old Mar 2, 2026 | 10:47 AM
PMWilson57's Avatar
PMWilson57
Cheers I also put it up on jacks and of course the not fully engaged noise went away. well I will keep y'all posted thanks for the advice as always..
Old Mar 2, 2026 | 04:34 PM
Try running it a bit in 4x4 on the stands, and apply the brake some to put a load on the driveline.
Old Mar 2, 2026 | 06:23 PM
PMWilson57's Avatar
PMWilson57
no I cant spin when axles engaged or in 4wd
