Front trailing arm bracket to axle
Old Mar 26, 2026 | 03:41 PM
jpilk99's Avatar
jpilk99
Default Front trailing arm bracket to axle
The front trailing arm (on passenger side) let go off the axle, see pics. Curious if anyone has had to deal with this - I'm told there are brackets available to repair? I have a good welder available, but just hoping to find an existing, tried & tested, solution. Thank you!!!
Old Mar 26, 2026 | 05:03 PM
Yep. You aren't the first. I think there is a thread around here about just such a topic, it's been a few years ago though.
Old Mar 27, 2026 | 01:49 PM
jpilk99's Avatar
jpilk99
Appreciate the feedback. I've searched but not found anything - are my "terms" correct, is that a "front trailing arm"? Or is it called something else?
Old Mar 27, 2026 | 02:05 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Technically called a control arm. I will say back when I was 16 owning these trucks and living in PA we made our own out of 1/4 steel and a grinder. Just matched the shape the best we could.
I did a triple pass with a 110 Lincoln and it is holding to this day.
Old Mar 27, 2026 | 03:42 PM
Did a bit of searching... Parts are not available. So, either make some new ones, or, get another axle, and swap it out.
Old Mar 27, 2026 | 05:15 PM
jpilk99's Avatar
jpilk99
I found this site/page but doesn't look like the bracket is a 'part' i can buy:
Old Mar 27, 2026 | 05:16 PM
jpilk99's Avatar
jpilk99
Thanks Brother. I think that's what I'm going to have to end up doing. Greatly appreciated - ALL
Old Mar 27, 2026 | 05:58 PM
DerTruck's Avatar
DerTruck
No idea if they will fit the control arm but there are similar looking replacement mounts available for TJ Jeeps. You'd still have to fab the upper part but you'd have the factory style adjustment capability.
Old Mar 28, 2026 | 10:53 AM
Keith_L's Avatar
Keith_L
Yeah I don't know how comfortable I'd be trying to weld to the axle tube given the rust. How far to a rust free zone? These housings are a dime a dozen in the West.
Old Mar 28, 2026 | 11:13 AM
In that case, (if you are IN the west....) I would just replace the whole thing, and call it a day.
